Quick bit of history. We originally had a wooden bow for my daughter which came with some 14xx jazz arrows. We upgraded her bow to a Hoyt Excel 21" riser. She then outgrew the arrows. At that point the arrows wouldn't reach 30yards. We tried out some acc arrows which worked better even though technically they were too tough. The ACC arrows are 1500 spine and technically far too stiff.
Her form has been improving and her draw weight has been increasing so I thought I'd give aluminium arrows a try again given that the spine should match better. I found a set of brand new uncut 1214 shafts for sale cheap, so snapped them up.
Now I'm trying to work out what is best to use on them. They are direct fit for g nocks just like the ACC were, so can I use the ACC points as well? They look to fit but have a slight lip as I presume the outer diameter of the tribute shafts is less than the ACC arrows.
I'm not certain what poundage she is pulling right now, I'll weigh later but I expect it is around 15# otf.
I'm also not sure on her draw length but will measure that later too.
So my questions are, is it ok to use the ACC points?
What fletchings would be best? I have some spare little shield vanes. Are they ok? How far back would be best for the fletchings on this?
Also cut out not? Obviously they will be far too long uncut, like this she won't be able to use her clicker (sight mounted magnetic).
