Any use for fallow deer antlers?
Zhoo Zhoo
Hubby came home with two fallow deer antlers today as a present for me - how romantic is that? :boggled: Ha ha! So I was wondering if they are any good for anything such as fashioning nocks or in place of horn for self nock reinforcements?
Raven's_Eye
I'm not sure but I was told that deer antlers are rather brittle and aren't as good for nocks.
there are other uses though, bow stands, knife handles, whistles.
Mark31121
I'm not sure about archery uses (apart from the decorative aspect) but they make great dog chews - high in calcium but kinder on the teeth than bones :)
Zhoo Zhoo
I was thinking about making a bowstand, so that's probably going to be the best option then, as I don't have a dog! Thanks guys. ☺
A friend of mine gave me a short length of a reindeer antler. It was tough as hell to cut. I cut it with a junior hacksaw length-ways into thin slivers and glued (Araldite 24hr) a piece into the self nocks on my wooden arrows. Across the line of the bow string of course.
WillS
Antler makes excellent bow nocks. Make sure you get rid of the porous center part, but it's far better than buffalo horn, and almost as good as cow horn for bow nocks.
bobbyger74
Ive seen them used for arrow rake handles. just drill a hole in the bottom and glue a length of bent metal rod in the hole.
bobbyger74
Just made this arrow rake today. Makes a good use of deer antler I think.
Just used a long narrow paint roller and removed the handle. I then drilled a hole in the antler and glued the metal rod in place using epoxy resin.
- - - Updated - - -
