Arrow Holding Foam
Hello.
The foam that holds the arrows in my Dcut case has deteriorated to the point where the arrows fall out when I open/close the case! If you have experienced the same problem? What did you do - replace the foam? Or did you come up with an alternative.
Thank you
Since posting my question I have found some 'Gymnasium Floor Matting'. If I can get it to stick to my case I thing it will do the job (It cannot be any worse than the current foam).
You can source virtually any type of foam on ebay in a huge variety of sizes. Some suppliers will even cut to your specified size.
Double sided carpet tape should stick the foam, and if it doesn't it's not too messy to remove to try the second attempt. :)
What did I do? I didn't use it enough for it to deteriorate; I went to a backpack and arrow tube(s)!
