Arrows for field
AndyW
A lot of field courses don't like carbons because of the way they can break up.
Maybe it's a throwback to years gone by when they could splinter horribly. The original Beman carbons were pretty deadly when they splintered. Modern decent carbons are not the same animal ( I put the caveat in to eliminate the cheap pultruded arrows or converted tent poles people really ought to know better than to buy ).
It's not an issue on NFAS field courses and you tend to only see kids/beginners shooting Allies, there's the odd person who shoots them but I would go with 90+% are either wood or carbon as a rough guess and I've not known a problem with them.
On one shoot hosted by Liberty archers we even shoot at a steel target (Robodeer) where anything except the kill zone will shatter your arrow - you just pick the busted arrow up and stick it in the top of the boss to be collected later, no issues - just great fun, everyone takes a couple of cr*p arrows knowing they're likely to be destroyed.
Kernowlad
That's great. I tend to manage the odd 24 and rarely get to the plenty. Managed a first arrow shoot once or twice but generally only tend normally 1 or 2 second arrows. I've even managed a blank. Any second arrows you're gonna admit to?
Yep one total miss; hit the boss but too high. More misjudging of distance
I shot with two other compounders; a first (except for when I shoot with my son)! Nice to not feel like a bit of a leper!
Just nice to be out there.
While I don’t know the construction method of the arrows, I suspect Easton do a good job so no splintering; I’m sure I’ll find out soon!
brman
fwiw, a clubmate had an ACE splinter very badly recently. It apparently glanced off the wood surround of the boss and was squashed (d shaped rather than round) and splintered over about 1/3 of its length. Not something I would want to pick up by the wrong end....
EDIT: actually, thinking about it, it was more likely an ACC.
Kernowlad
Carbon can be nasty and so often used inappropriately. Depends on how it’s “laid.”
I’m quite into MTBing where the carbon wand is waved too often, works well on some parts (bars, brake levers), really doesn’t on others (saddle rails; mine snapped), frames, seat posts, bottle cages, etc.
Hopefully my arrows will be okay; every compound field archers I’ve met uses carbon arrows:
Magna Carta have 'RoboDuck'. :D (and yes I've smashed a few arrows on it)
ArcheryFox
I realise this is an old thread, but thought I'd throw my 2 cents in as others will undoubtedly have the same question and look here in future...
I recently destroyed the last of my old Easton profields that I had been using since I first started field.
Looking for something to replace them that was cheap, light, and affordable I eventually settled on Victory VAPs.
These are fully carbon, made to similar tolerances* as the top Easton arrows, and about £10 per shaft.
When I emailed my local shop to enquire the owner phoned me back specifically to tell me how great he had found these arrows and how keen he was for another VAP shooter!
Shooting has been limited recently but I have found them excellent, and shot similar scores in practice to the profields.
Of course, more testing is needed - including in competition - but so far I am pretty impressed and glad I tried them.
The ice coating makes them really easy to extract from 3D's and tight targets compared to my other arrows, and they also have the stiffest spine orientation marked on the arrow saving you having to test for it and nock turn yourself.
IMO they are the right balance of weight for nice stable flight whilst giving a reasonably short sight tape, though this is a personal opinion - if I were to make a set for target I'd probably go longer, stiffer, and heavier.
I realise that chunky arrows are all the rage for 3D, but personally I subscribe the Broadwater theory of shoot whatever works properly, you have faith in, and hits where you aim, rather than try and grab a line when you miss ;).
I tend to shoot more spots than 3Ds and can't afford different setups for each, and, at the moment, feel that my shooting is stronger than my distance judging so thinner lighter arrows are in my interests.
As you may have gathered this is for a compound, but they should work equally well for non-wheely bows, and there is also the VXT you can consider in this case. It also depends on your skill level and what you plan to do - if you think you'll miss a lot maybe you want the cheapest arrows possible :p.
With reference to other questions raised in the thread:
- I have never had issues with all carbons in field, only target - indeed they seem to be more popular amongst the field crowd than A/C - and if I lose something behind a target in dense carpeted forest off a compound I know from experience it's probably gone, metal detector or no (RIP that one protour :cry:).
- I have found the Beiter hunter nocks to give excellent protection against rear-end impact, especially when coupled with pins and collars.
* in making there was a 0.8 grn variation in the shaft weights (except one which was suspiciously 1grn heavier) compared to 0.9 grn in my set of protours (but no outliers). After making and matching points the weight tolerance of both sets was about the same - but the price wasn't!!
