tony08
It seems (and correct me if I'm wrong) that most bows have a bracing height tolerance of about half an inch, say between 8" and 81/2", or whatever depending on the bow etc.
My question is how many twists can you put into a string to adjust this? Is is acceptable to put enough in to move the bracing height up by half an inch?
How many twists would it require to shift a bracing height from 8" to 81/2"?
I know that it all depends on the material of the string, bow spec. etc. but as a general guide, is this 1/2" range normally dealt with by twisting, or is a shorter string normally advised?
