In short, I'll be getting a compound later this year and I'd like to get a sight i can use on both compound and recurve to save some money.
First off, any recommendations?
I like the look/function of the HoggFather but can a regular sight pin be attached?
Also, can the compound pins/tunnels be used or is the tunnel more than 2cm?
Nick
Thanks!11.1.5. A bow sight is permitted, but at no time may more than one such device be used.
11.1.5.1. It shall not incorporate a prism, lens, or any other magnifying device, levelling, electric or electronic devices nor shall it provide for more than one sighting point.
11.1.5.2. The overall length of the sighting circle or point (tunnel, tube, sighting pin or other corresponding extended component) shall not exceed 2cm in the line of vision of the athlete.
11.1.5.3. A sight may be attached to the bow for the purpose of aiming and which may allow for windage adjustment as well as an elevation setting. It is subject to the following provisions:
- A bow sight extension is permitted;
- A plate or tape with distance marking may be mounted on the sight as a guide for marking, but shall not in any way offer any additional aid;
- The sight point may be a fibre optic sight pin. The total length of the fibre optic pin may exceed 2cm, provided that one end is attached outside the athlete?s line of vision at full draw, while the part within the athlete?s line of vision does not exceed 2cm in a straight line before bending. It can only provide one illuminated aiming spot at full draw. The fibre optic pin is measured independently of the tunnel.
Nick
