New string and cables
Sinbad
Hi All,
So i am looking at changing the string and cables on my PSE supra ME (old like me, but new when i got it many years ago). Would you stick with the original string and cables from PSE, or would you go for something like Winners etc, or even have them made as i have done in the past. Don't have time to make my own, or the skills. Need to be black and red to keep the look ;)
Thanks all
Sinbad
I have looked at the soloflex and the price is very good. I can see the material used is fine, has anyone used them, any issues etc.
jerryRTD
Hi All,
Thanks all
getting the srings and cables is one thing fitting them and setting up the bow is some thing else. If you do not have a bow press then perhaps you should think abput buying from your nearest archery shop?
Sinbad
Fitting and setting up are not an issue, have done them including cams in the past. Just wanted to know if any recommendations were out there for brands.
Another vote for reign , probably have about 5000 shots in my latest set with zero peep rotation or change in any bow specs
Sinbad
Cheers for the responses, I will look at reign and will contact them I think. Reading online, you get lots of different info but always find it best to ask those that do it without bias.
upinsmoke
I went with Flexarchery Soloflex strings and cables for a PSE stinger. Takes a about week for them to arrive from Spain.
Sinbad
Well ended up getting a winner choice. All setup and feels firmer than the last string from last year. Seems a little shorter with the draw as well but could be the other had stretched. Tuned and set. Only 50 shots through due to time and weather, but feels better. Even the peep has settled in line. Thanks for all responses people.
