Number of laminates?
Clynester1
I am looking at getting my first longbow and have spotted a couple of longbows in stock that are immediately available. One of them is a three-laminate bow (bamboo, padauk, ipe) and the other is a four-laminate bow (bamboo, padauk, ipe, ipe). For an extra ?50, would the extra laminate be worth it to a complete starter in the longbow world? Both bows are the same weight (48lbs at 28?). Comparatively, what benefit in general (value for money notwithstanding) do multiple laminates have on a bow? My dad?s is five laminates, but I have no idea how that compares to other bows.
"For an extra ?50, would the extra laminate be worth it to a complete starter in the longbow world?"
Short answer ... No
Longer answer,
reasons for using laminates:-
1. You can match the wood with it's properties suited to its position in the bow. e.g the back is under tension, the core needs to be stable, light and resistant to crushing, the belly need to be good in compression.
2. It allows slats of wood which would otherwise be scrap to be used. Eg, wood with swirling grain would be ok in the core but not as back or belly.
3. Multiple thin laminates allow a bow to be glued up into quite tight recurves (not applicable to an English longbow, although they can be glued up with a slight reflex or back-set.)
4. To make the bow look pretty. e.g I did a boo/Purpleheart/Yew which looked like a jam sponge cake, for a lady archer. :)
From the above you can see that 3 laminates is plenty, often a simple backed bow is fine.
I recently made a series of 3 ELB for a flight shoot. 2 were boo/Yew, one was Boo/Yew/Ipe ... the fastest was a Boo/Yew
PS. To me there is an implication that a 4 lam should be cheaper not more expensive as it is using up wood that is otherwise too thin.
Otherwise why would you have two Ipe lams on the belly? Bonkers!
Ifor_Bentun
I don't know if it's true but I was once told a 4 lam bow was stronger than a 3 lam because of the extra glue line.
Guthormsen
there are lots of differences in laminations. mixing wood types effects the bow as does even the adhesives and thicknesses of glass. the order in how they are laminated even matters.
shoot the bow, if you like it then buy it.
if you wanted specics I could supply that
Guthormsen
Surely five laminates is plywood. :)
simply speaking, the more laminates the stronger it is; provided you did your job properly.
However that doesnt necessarily make the bow what the greatest potential it is capable of! ; Which is the sole purpose of building your own bows.
