SF Premium Carbon Sight
goz1960
Please could anyone help regarding the damaged screw that i need to replace on my sight? it is the one that goes where the alenkey is any help would be appreciated.
Do you need to know a size so you can source a replacement?
Do you know the size and need a replacement?
Is there part of a screw broken off inside that needs extracting?
What is the exact nature of your emergency caller :) ??
Another way to lock the sight aperture is to screw a nut onto the end of the threaded rod and tighten it up to the block. 8-32" is the thread of the rod. If they aren't readily available, M4 nuts will fit and they are much easier to source.
EVC
By the looks of it, that small grub is most likely M3.
