Hi
When using the Sure loc x-press, where on the limbs should the big wheels make contact? I've got a Mathews Conquest Triumph. I've worked out that it's not at the tip because the bracket fittings aren't the same thickness. So that leaves just below on the bit of the limb that has the small split or further down on the solid part of the limb.
Cheers,
Martin
Cheers,
Martin
