Hi Geoff,
No probs. I was just a bit concerned that someone new to Clout could get the wrong end of the stick.
Hi David,
Perhaps I have misunderstood GNAS, but they seem to be saying that longbows are allowed to use the high elevation technique, ie greater than 43 degrees. Why would longbows do this, as it would result in a shorter range. Because of the design of the
longbow and its arrows it tends to have a shorter cast than, say, a
recurve of the same draw weight. So, as you say,
longbow archers need to use a much higher angle of elevation to get the distance that they require and this might look like the high elevation technique, but it still won't exceed 43 degrees as that would be counterproductive. Next time I am at a clout I will take my camera with me (after having been registered) and then I will analyse the images later to determine exactly what angles are being used.
Regards,
Dave
