The problem is you haven't defined any of your terms or what sort of bow you are talking about.
If you are talking about modern materials and deflex/reflex designs they are all so good and have so much spare performance it is probably pretty irrelevant.
E.g they can all probably be over drawn by a good 6" with no problem.
If you are talking about wooden bows and "long" being in excess of say 6' 6" the length adds considerable inertia.
Simplest way to illustrate is twanging a wooden school rule on your desk, as you shorten it the note becomes higher. Short limbs tend to be faster, long limbs tend to be smoother and better suited to shooting heavier arrows.
e.g My best flight distances are similar from a 100# @ 32" warbow (Elm) and a 70# @ 24" flight bow (Osage) yet the warbow has a lot more energy put into it.
In terms of force draw curve with wooden bows, adding reflex gives good early draw weight (which shows in the F/D curve) but limits draw length as there is only so much you can get from a bow.
The whole stacking thing is more about geometry than the materials.
All those F/D curves are pretty much the same, being from moder deflex reflex designs), longbows are remarkably linear and if you realy want extreme shape to the FD curve you need to be looking at Asiatic composite designs or compounds (spits on floor). Once Hickman had come up with the basic moder deflex/reflex design*, the rest is small incremental improvements.
*He came up with the design using a F/D curve plotting machine which he built. He did it to allow him to compete despite having lost some fingers in a rocketry accident which meant he coulld no longer pull 50#, his design allowed his 35# bow to out shoot the 50#.
There is an biography of Hickman which is a good read:-
Clarence N Hickman the father of scientific archery ISBN0-9613582-0-3
Note:- all just my opinion of course, terms and conditions apply and I reserve the right to be wrong (especially if my wife says I am
