The draw length on my bow is too long to use a BT release properly.When you say the problems you had were mainly "me", what sort of problems did you have? If it was with the shape of the handle, for example then the target 4 could give you similar ones.
Then you found the problem.The draw length on my bow is too long to use a BT release properly.
Have you reduced the draw length now? If its too long, it'll be too long whatever release you use.The draw length on my bow is too long to use a BT release properly.
why not just twist the string up in the meantime?I'm going to get the draw length shortened in July when the string needs to be replaced.
sure, but how it felt to me isn't going to make any difference to how well it suits you. I could say it was the best release I ever used and you might still not like it.Anyway, has anyone shot with a Carter Target 4?
I don't have a bow press.why not just twist the string up in the meantime?
for the record, I don't think 4-finger releases are a great idea. 3 finger seems to work much better at promoting a relaxed hand position.
