misstheboss1973
Hi all, just after a bit of advice please...
About to buy my first 'proper' set of 12 arrows and wouldn't mind getting it right first time.
Will be shooting mainly field and 3D with a Bear Anarchy HC at 70lb, currently feeling comfortable with a 29" DL. Use a wrist release and drop away rest.
I like the Easton Full Metal Jacket arrows based on their price, durability and GPI. However with my current settings I come out on the J of the Easton chart...but only just. This suggests a .340 spine. However, if I were to change anything, such as shorten my arrows (I'm currently shooting a few at 29.5"...more than the 1" past the rest suggestion with a 100g point) or use a 125g point I'd be in the K column, which recommends a .300 spine.
So, do you think I should just get the 340s or the 300s? Know its better to be overspined than under, but not sure how flexible you can be with the advice on the selection charts. Will accuracy be significantly affected with a .40 difference in spine?
Any advice would be much appreciated! Thanks...
