T101
worth a look, think he's running 50lb draw weight last I heard too. which would make about 50% let off with holding weight stated. WTPS w Reo Wilde - YouTube
Thanks for posting the link... really interesting. I was particularly interested in Reo's holding weight. He says he's holding 25lb. I haven't shot hoyt for about 15 years. Back then I was holding 30lb on carbon plus with 50% let-off. I'm pretty sure his pro elite can't go below 65% let-off so he must be pulling 70lb. If anyone knows if you can get a hoyt down to 50% let-off I would love to know.he was back up to 60lbs in the last World Cup stats I've seen for this year
Really, 55%... if I had known that I would have looked at the Hoyt a bit closer when I changed from Mathews. I use heat shrink on my pse stops to tweak the draw length. It works very well.it might not be an as-standard stop... add a bit of shrinkwrap to a normal stop to widen it a little, stick it in the 55% hole and you'll be starting to push towards 50%... actually, 55% is one of the settings on a Spiral cam and 55% letoff at 60lb is... 27lb!
What have you done to get the Supra to 65%? Just the bigger stop (shrinkwrapped)?Thanks for posting the link... really interesting. I was particularly interested in Reo's holding weight. He says he's holding 25lb. I haven't shot hoyt for about 15 years. Back then I was holding 30lb on carbon plus with 50% let-off. I'm pretty sure his pro elite can't go below 65% let-off so he must be pulling 70lb. If anyone knows if you can get a hoyt down to 50% let-off I would love to know.
My SupraMax is down to about 65% let-off, about 20lb holding + 5lb against the`wall is about 25lb. But I would love to be back at 30lb holding.
No. I set the draw stop at 29.5", my draw length. But I set the cam modules to the 30" draw position. This means I don't drop into the valley as I would if the cams were also set to the 29.5" position, as Bimble was saying earlier. However, the adjustment is crude on the down slope in to the valley so I use heat shrink wrap to tweak it, more for draw length than draw weight.What have you done to get the Supra to 65%? Just the bigger stop (shrinkwrapped)?
There are three stop positions on the Spiral X cams for 65/60/55% let off.Really, 55%... if I had known that I would have looked at the Hoyt a bit closer when I changed from Mathews.
At the Hoyt seminar I went to at the European Archery Festival, Reo was held as an example of someone you might not want to copy... and just think of the savings in buying weights if you don't!!Also found it curious that he seems to like a lot of stabiliser weight with a higher let off.
A consistent theme from my coach is to point at some of the highest scoring archers around and say "that's their style, it works for them, don't copy them, start with classically good form/setup and then work yourself out from there"At the Hoyt seminar I went to at the European Archery Festival, Reo was held as an example of someone you might not want to copy... and just think of the savings in buying weights if you don't!!
Yes, that's the way I had set mine too - for me that gives a let off of 62%. I love how smooth the ME cams are when set that way. But as you say! you can't relax at full draw even a bit...No. I set the draw stop at 29.5", my draw length. But I set the cam modules to the 30" draw position. This means I don't drop into the valley as I would if the cams were also set to the 29.5" position, as Bimble was saying earlier. However, the adjustment is crude on the down slope in to the valley so I use heat shrink wrap to tweak it, more for draw length than draw weight.
You have to be prepared to have your anchor ripped from your face if you drop the back tension. Not forgiving... but I like that.
Thanks for the suggestion, but as Bimble pointed out this afternoon, I have the Arctec drawstops fitted :duh:@Gonebad
Might be worth double checking the module positions. A few times I've set the little pins in the next position down. Actually spent four months and a couple of RS events with the modules in different holes. Didn't make much difference to my shooting though. Bow still tuned fine.
I have the triangular ones. Easy to fit and they haven't moved. I feel that there is a noticeable improvement in wall solidity mostly due to the bottom limb stop. Of course, having the let-off lowered to 65% makes the bow better for me to shoot. Having looked at the hexagonal ones on Bowsports they show a diagram for high, medium and low let-off positions so the triangles must also be made to alter let-off.How are you finding them?
